Quick view sku: FOR-IRK-350.348 RB 2 pc Rotor Kit for Ford Raptor (2009+) Stock Replacement Front & Rear (Select Option for Your Rear Brake) MSRP: $2,700.00 Now: $2,555.00 Choose Options Compare Quick view sku: FOR-IRP-350.348 RB 4/2 pot Caliper Brake Kit (350/348) for Raptor 2009+ (P/N: 2570-K & 2571-K) - Fits most 17" wheels except OE Beadlock; (Rear is for drum brake only & NOT w/ePB) MSRP: $5,800.00 Now: $5,510.00 Pre-Order Now Compare Quick view sku: FOR-IRP-350.348 (OE-Beadlock) RB 4/2 pot caliper Brake Kt (350/348) for Raptor (2009-2023) Fits OE 17" Beadlock Wheels w/A Tight Space (P/N: 2577-K, 2571-K), (Rear is for drum brake only & NOT w/ePB) MSRP: $6,200.00 Now: $5,889.00 Pre-Order Now Compare Quick view sku: FOR-IRP-400.390 RB 6/4 Pot Caliper BBK (400/390) for Ford Raptor 2009+ Front and 2012+ w/ Rear Drum Brake (P/N 2615-K & 2616-K) MSRP: $9,750.00 Now: $8,977.50 Choose Options Compare Quick view sku: 1503-21-321 Rotor Rings (348x26) for F150 Rear Replacement (Price is for pair) - Hardware are included. MSRP: $895.00 Now: $849.00 Add to Cart Compare Quick view sku: 1503-09-321 Rotor Rings (380x30x66) (Price is for pair) - Hardware are included. MSRP: $1,001.00 Now: $950.95 Choose Options Compare Quick view sku: 1503-08-321 Rotor Rings (390x34x71) (Price is for pair) - Hardware are included. MSRP: $1,001.00 Now: $950.95 Choose Options Compare Quick view RB 2 pc Rotor Kit for Ford Raptor (2009+) Stock Replacement Front & Rear (Select Option for Your Rear Brake) Kit Inclues: 2 ea Front 2 pc rotors (350x34mm) 2 ea Rear 2 pc rotors (348x26mm) - Drum parking, or (336x24mm) - ePB Weight Info: Replacement rotor ring: Front: D501-12 Rear (Drum): 1503-21 Rear (ePB): D308-02 MSRP: $2,700.00 Now: $2,555.00 Choose Options Compare Quick view RB 4/2 pot Caliper Brake Kit (350/348) for Raptor 2009+ (P/N: 2570-K & 2571-K) - Fits most 17" wheels except OE Beadlock; (Rear is for drum brake only & NOT w/ePB) Kit includes: 2 RB460 4 pot calipers 2 front caliper adaptors 2 front 2 pc rotors (350x34mm) 1 set front brake pads 2 RB24 2 pot calipers 2 rear caliper adaptors 2 rear 2 pc stock size rotors (348x26mm) 1 set rear brake pads Caliper Info: Weight... MSRP: $5,800.00 Now: $5,510.00 Pre-Order Now Compare Quick view RB 4/2 pot caliper Brake Kt (350/348) for Raptor (2009-2023) Fits OE 17" Beadlock Wheels w/A Tight Space (P/N: 2577-K, 2571-K), (Rear is for drum brake only & NOT w/ePB) Kit includes: 2 RB4050 4 pot calipers 2 front caliper adaptors 2 front 2 pc rotors (350x32mm) 1 set front brake pads 2 RB24 2 pot calipers 2 rear caliper adaptors 2 rear 2 pc stock size rotors (348x26mm) 1 set rear brake pads Caliper Info: Weight... MSRP: $6,200.00 Now: $5,889.00 Pre-Order Now Compare Quick view RB 6/4 Pot Caliper BBK (400/390) for Ford Raptor 2009+ Front and 2012+ w/ Rear Drum Brake (P/N 2615-K & 2616-K) Replacement pads: PD1668.PD968 Replacement rotor rings: Front: D601-03 Rear: D603-02 Wheel fitment template: Front kit: 2615-K Rear kit: 2616-K MSRP: $9,750.00 Now: $8,977.50 Choose Options Compare Quick view Rotor Rings (348x26) for F150 Rear Replacement (Price is for pair) - Hardware are included. Kit contains:2 ea Discs20 ea Hardware set Material: Alloyed iron formula adds stre MSRP: $895.00 Now: $849.00 Add to Cart Compare Quick view Rotor Rings (380x30x66) (Price is for pair) - Hardware are included. These rotor rings are made of alloyed cast iron for a direct replacement to OE two piece rotors (re-use of OE rotor hats). Hardware is not included but can be purchased here: McLaren hardware MSRP: $1,001.00 Now: $950.95 Choose Options Compare Quick view Rotor Rings (390x34x71) (Price is for pair) - Hardware are included. MSRP: $1,001.00 Now: $950.95 Choose Options Compare Compare Selected × OK
