Quick view sku: Z06-53R Corvette Z06 (PZ-41) Pad EZ Bolt Rear Axle Set (12 pcs) Available on Amazon MSRP: $155.10 Now: $147.35 Add to Cart Compare Quick view sku: Z06-53R-2 Corvette Z06 (PZ-41) Rear 4 Pot Caliper Brake Pad EZ Bolt ( 2 pcs/pack ) MSRP: $26.50 Now: $25.20 Add to Cart Compare Quick view sku: Z06-53F Corvette Z06 (PZ-61) Pad EZ Bolt Front Axle Set (16 pcs ) Available on Amazon MSRP: $206.80 Now: $196.46 Add to Cart Compare Quick view sku: Z06-53F-2 Corvette Z06 (PZ-61) Front 6 Pot Caliper Brake Pad EZ Bolts ( 2 pcs/pack ) MSRP: $26.50 Now: $25.20 Add to Cart Compare Quick view sku: GM-C6-Z51 RB 2Pc Rotor Kit (340x32/330x24) for C6 Corvette Z51 (05-09) Front & Rear (P/N 2068 & 2069) MSRP: $1,870.00 Now: $1,776.50 Add to Cart Compare SALE Quick view sku: GM-C6-Z06 RB 2 Pc Rotor Kit (355x32/340x26) for C6 Corvette Z06 w/PBR 6/4 Pot Caliper (P/N 2072 & 2073) - Disc Finish: Drills & Slots MSRP: $2,585.00 Was: $2,455.75 Now: $2,209.50 Choose Options Compare Quick view sku: C6-IRK-01 RB 2Pc Rotor Kit (390x36/380x32) for Corvette C6 ZR1 / Z06 Carbon Edition w/CCM Rotors Conversion to Iron Rotos Front & Rear (P/N 2242 & 2243) MSRP: $3,145.00 Now: $2,988.00 Choose Options Compare Quick view sku: 2148 RB 2pc Rotors Surface-mt (355x32mm) for C6 Corvette Z06 & Grand Sport 2006-13 Front MSRP: $1,045.00 Now: $992.75 Add to Cart Compare Quick view sku: GM-IRP-01 RB 6/4 Pot Caliper Kit (360x32/360x26) for C5/C6 Corvette 97-13 (P/N 2371-K & 2402-K) MSRP: $7,063.10 Now: $6,709.95 Compare Quick view sku: GM-IRP-10 RB 6/4 Pot Caliper Kit (390x36/380x30) for Corvette C5/C6 Upgrade to C6 CCM Rotor Size (P/N 2242-K & 2243-K) MSRP: $7,139.00 Now: $6,782.05 Add to Cart Compare Quick view sku: C6-IRK-02 RB Light Wt 2Pc Rotor Kit (390x32/380x30) CCM to Iron Conversion for Corvette C6 ZR1 / Z06 Carbon Edition (P/N 2390 & 2372) MSRP: $3,150.00 Now: $2,990.00 Choose Options Compare Quick view sku: D308-04-351 Replacement Rotor Ring (Drill+Slot) for CORVETTE Z06 REAR MSRP: $613.80 Now: $583.11 Add to Cart Compare Quick view sku: 1406-03-311 Rotor Rings (355x32) for Corvette C6 Z06 Front Includes Hardware (Price per pair) MSRP: $856.90 Now: $814.06 Add to Cart Compare Quick view Corvette Z06 (PZ-41) Pad EZ Bolt Rear Axle Set (12 pcs) Available on Amazon Click here: This brake pad EZ bolt is designed and made exclusively by RacingBrake to replace the bolts that come with the original caliper and tend to bind to the caliper and break.RB EZ bolts are made of high strength alloyed steel and heat-treated. MSRP: $155.10 Now: $147.35 Add to Cart Compare Quick view Corvette Z06 (PZ-41) Rear 4 Pot Caliper Brake Pad EZ Bolt ( 2 pcs/pack ) This brake pad EZ bolt is designed and made exclusively by RacingBrake to replace the bolts that come with the original caliper and tend to bind to the caliper and break.RB EZ bolts are made of high strength alloyed steel and heat-treated. Qty: 2... MSRP: $26.50 Now: $25.20 Add to Cart Compare Quick view Corvette Z06 (PZ-61) Pad EZ Bolt Front Axle Set (16 pcs ) Available on Amazon Click here: This brake pad EZ bolt is designed and made exclusively by RacingBrake to replace the bolts that come with the original caliper and tend to bind to the caliper and break.RB EZ bolts are made of high strength alloyed steel and heat-treated... MSRP: $206.80 Now: $196.46 Add to Cart Compare Quick view Corvette Z06 (PZ-61) Front 6 Pot Caliper Brake Pad EZ Bolts ( 2 pcs/pack ) This brake pad EZ bolt is designed and made exclusively by RacingBrake to replace the bolts that come with the original caliper and tend to bind to the caliper and break.RB EZ bolts are made of high strength alloyed steel and heat-treated. Qty: 2... MSRP: $26.50 Now: $25.20 Add to Cart Compare Quick view RB 2Pc Rotor Kit (340x32/330x24) for C6 Corvette Z51 (05-09) Front & Rear (P/N 2068 & 2069) MSRP: $1,870.00 Now: $1,776.50 Add to Cart Compare SALE Quick view RB 2 Pc Rotor Kit (355x32/340x26) for C6 Corvette Z06 w/PBR 6/4 Pot Caliper (P/N 2072 & 2073) - Disc Finish: Drills & Slots Replacement rotor rings: Front: D402-01-351 Rear: D308-04-351 Replacement brake pads Installation Notes: Rear rotor installation requires trimming the lip of backing plate to avoid interference w/two piece rotor harware. It is requiried to remove the... MSRP: $2,585.00 Was: $2,455.75 Now: $2,209.50 Choose Options Compare Quick view RB 2Pc Rotor Kit (390x36/380x32) for Corvette C6 ZR1 / Z06 Carbon Edition w/CCM Rotors Conversion to Iron Rotos Front & Rear (P/N 2242 & 2243) Kit Contents: 2 ea Front 2pc rotors (390x36 vs. 394x36mm). Our rotors fits better than OE 394mm that eliminate the undesirable rusty lips. 2 ea Rear e pc rotors (380x32 vs. 380x34mm) 1 set brake pads made for iron rotors - Optional Feature &... MSRP: $3,145.00 Now: $2,988.00 Choose Options Compare Quick view RB 2pc Rotors Surface-mt (355x32mm) for C6 Corvette Z06 & Grand Sport 2006-13 Front Contents: 2 ea. surface mount 2-PC rotors (only straight slot finish available) 1 ea. front set RB street performance brake pads. MSRP: $1,045.00 Now: $992.75 Add to Cart Compare Quick view RB 6/4 Pot Caliper Kit (360x32/360x26) for C5/C6 Corvette 97-13 (P/N 2371-K & 2402-K) Kit includes: 2 RB 6-Piston front calipers) 2 Front rotors (360x32mm) 2 Front caliper adaptors 2 RB 4-Piston rear calipers 2 Rear rotors (360x26mm) 2 Rear caliper adaptors 1 car set brake lines 1 car set brake pads Wheel fitment... MSRP: $7,063.10 Now: $6,709.95 Compare Quick view RB 6/4 Pot Caliper Kit (390x36/380x30) for Corvette C5/C6 Upgrade to C6 CCM Rotor Size (P/N 2242-K & 2243-K) Links to customer reviews:http://forums.corvetteforum.com/c6-corvette MSRP: $7,139.00 Now: $6,782.05 Add to Cart Compare Quick view RB Light Wt 2Pc Rotor Kit (390x32/380x30) CCM to Iron Conversion for Corvette C6 ZR1 / Z06 Carbon Edition (P/N 2390 & 2372) Kit Contents: 2 ea Front two piece rotors 2 ea Rear two piece rotors 1 set Front street pads 1 set Rear street pads This car kit is specially packaged with a 10% saving over purchasing the individual kits. It's being sold as a bundle so you must... MSRP: $3,150.00 Now: $2,990.00 Choose Options Compare Quick view Replacement Rotor Ring (Drill+Slot) for CORVETTE Z06 REAR Hardware included. MSRP: $613.80 Now: $583.11 Add to Cart Compare Quick view Rotor Rings (355x32) for Corvette C6 Z06 Front Includes Hardware (Price per pair) Contents: 2 ea. surface mount rotor rings (including hardware) Features & benefits: Reduced rotating mass and unsprung weight - Save over 7 lbs per rotor over OE's heavy 1-PC rotor resulting in bett MSRP: $856.90 Now: $814.06 Add to Cart Compare Compare Selected × OK
