Quick view sku: PD-GTR-360-1 [PD-GTR-360-1] RB Street+ Pad Bundle: 09-20 Nissan GT-R 6/4 Pot CCM Rotors (& ZR1 upgrade) (PD1291 & PD968) - ST600 MSRP: $1,045.00 Now: $992.75 Choose Options Compare Quick view sku: PD-GTR-360 [PD-GTR-360] RB Street+ Pad Bundle: 09-20 Nissan GT-R 6/4 Pot CCM Rotors (PD1291 & PD968) - ST600 MSRP: $1,045.00 Now: $992.75 Add to Cart Compare Quick view sku: PD1291-360 [PD1291-360] RB Street+ Pads for CCM Rotors - GTR, Mercedes C63S etc. FRONT MSRP: $605.00 Now: $574.75 Add to Cart Compare Quick view sku: PD1395.PD968-TP [PD1395.PD968] Track Pads for RB6L & RB4M Calipers MSRP: $752.40 Now: $714.78 Add to Cart Compare Quick view sku: PD1666.PD968-391A [PD1666-PD968] Street Pads for RB6M Front (is OE Mustang GT500 13-14 Front) & RB4M (is OE GTR 07+ Rear) Calipers MSRP: $635.80 Now: $604.01 Choose Options Compare Quick view sku: PD1666.PD968-397 [PD1666.PD968] Track Pads for RB6M & RB4M Calipers MSRP: $880.00 Now: $836.00 Add to Cart Compare Quick view sku: PD968-360 [PD968-360] RB Brake Pads (ST600) for Nissan GTR, Lexus RCF Track Edition, RB4M Rear Calipers MSRP: $495.00 Now: $470.25 Add to Cart Compare Quick view sku: RBL-001 RacingBrake Front and Rear Stainless Steel Brake Line Set for Nissan GT-R R35 09+ (OEM Caliper Fitment) MSRP: $379.50 Now: $300.00 Add to Cart Compare Quick view sku: H031-K RB Hat & Hardware kit for Nissan GTR Front CCM Discs (390x32mm) are Not Included - Price is for Pair MSRP: $1,815.00 Now: $1,724.25 Choose Options Compare Quick view sku: H043-K RB Hat & Hardware kit for Nissan GTR Rear Upgrade to CCM Rotors (390x32 vs. 380x34mm) - Price is for 2 Hats MSRP: $1,925.00 Now: $1,828.75 Choose Options Compare Quick view sku: H006-K RB Rotor Hat & Hardware kit for Nissan GTR Front Retrofitted to GM CCM Discs (394x36mm-Not Included) - Price is for A Pair MSRP: $1,560.00 Now: $1,482.00 Choose Options Compare Quick view [PD-GTR-360-1] RB Street+ Pad Bundle: 09-20 Nissan GT-R 6/4 Pot CCM Rotors (& ZR1 upgrade) (PD1291 & PD968) - ST600 This pad kit is for those upgrade to CCM rotors with 390x32mm front (using Z28/C7 rear discs) whcih can only take 65mm depth pad (same as OE). If your front is ZR1 front (394x36mm) then you should order this pad kit. MSRP: $1,045.00 Now: $992.75 Choose Options Compare Quick view [PD-GTR-360] RB Street+ Pad Bundle: 09-20 Nissan GT-R 6/4 Pot CCM Rotors (PD1291 & PD968) - ST600 This pad kit is for those upgrade to CCM rotors with 390x32mm front (using Z28/C7 rear discs) whcih can only take 65mm depth pad (same as OE). If your front is ZR1 front (394x36mm) then you should order this pad kit. MSRP: $1,045.00 Now: $992.75 Add to Cart Compare Quick view [PD1291-360] RB Street+ Pads for CCM Rotors - GTR, Mercedes C63S etc. FRONT High metallic brake pads specially developed for Carbon Ceramic Rotors. Performance characteristics is comparable to Pagid RSC1 ($729) and OE Brembo. Consistent COF (Coefficient of Friction) Wider range of environmental temperature Excellent modulation... MSRP: $605.00 Now: $574.75 Add to Cart Compare Quick view [PD1395.PD968] Track Pads for RB6L & RB4M Calipers MSRP: $752.40 Now: $714.78 Add to Cart Compare Quick view [PD1666-PD968] Street Pads for RB6M Front (is OE Mustang GT500 13-14 Front) & RB4M (is OE GTR 07+ Rear) Calipers MSRP: $635.80 Now: $604.01 Choose Options Compare Quick view [PD1666.PD968] Track Pads for RB6M & RB4M Calipers MSRP: $880.00 Now: $836.00 Add to Cart Compare Quick view [PD968-360] RB Brake Pads (ST600) for Nissan GTR, Lexus RCF Track Edition, RB4M Rear Calipers High metallic brake pads specially developed for Carbon Ceramic Rotors. Performance characteristics is comparable to Pagid RSC1 and OE Brembo. Consistent COF (Coefficient of Friction) Wider range of environmental temperature Excellent... MSRP: $495.00 Now: $470.25 Add to Cart Compare Quick view RacingBrake Front and Rear Stainless Steel Brake Line Set for Nissan GT-R R35 09+ (OEM Caliper Fitment) This brake line kit was exclusively developed by RB and comes with all the necessary components for a complete installation for front and rear axles and replaces OE hard lines. These lines are built to RB specifications, meeting D.O.T. Certified. MSRP: $379.50 Now: $300.00 Add to Cart Compare Quick view RB Hat & Hardware kit for Nissan GTR Front CCM Discs (390x32mm) are Not Included - Price is for Pair The price includes all the components needed for assembling 2 front rotors (Discs GM P/N: 20981826 are not included). Brake pads are NOT included but can be added from option or purchased here: PD1291-360 (RB ST600) Installation Note: Installation of... MSRP: $1,815.00 Now: $1,724.25 Choose Options Compare Quick view RB Hat & Hardware kit for Nissan GTR Rear Upgrade to CCM Rotors (390x32 vs. 380x34mm) - Price is for 2 Hats Kit includes: 2 ea rotor hats (required rotors GM P/N: 20981826 are not included) 2 set of assembly hardware (RB design IB30-K) 2 ea caliper spacers for oversized rotors (from 380mm to 390mm) 4 ea M12x1.5x80 caliper mounting bolts - 80mm is all it needs... MSRP: $1,925.00 Now: $1,828.75 Choose Options Compare Quick view RB Rotor Hat & Hardware kit for Nissan GTR Front Retrofitted to GM CCM Discs (394x36mm-Not Included) - Price is for A Pair Kit inlcudes: 2 ea rotor hats made with forged aluminum hats 20 sets hardware kit (RB made) for assembling two front rotors 1 set caliper spacers for mounting larger rotors 1 set CCB brake pads (optional) The price includes all the components needed... MSRP: $1,560.00 Now: $1,482.00 Choose Options Compare Compare Selected × OK
