- 2 ea Front CCM rotors
- 2 ea Rear CCM rotors
- 1 car set ccb brake pads
- Direct bolt on installation for iron to ccb rotor conversion upgrade.
- Retains the use of stock calipers & pads (for ccb rotors)
- Dramatic unsprung weight reduction - Great value for iron rotors upgrade.
- Rotors are made of continuous carbon fiber for better strength than OE and directional vanes for better cooling.
- Low maintenance & replacement cost (cost less than 1/2 of OE replacement).
- Front pad: PD991-360
- Rear pad: PD1300-360
Fit the following models (For iron to ccb conversion only - Not for pccb replacement)
- 2001-2005 Turbo models
- 2006-2012 Turbo models WITHOUT Ceramic Brakes
- 2001-2012 Carrera S/Carrera 4S models (996 & 997 generation)
- 2021-2025 Cayman GTS 4.0
- 2021-2025 Boxster GTS 4.0 or 25th anniversary Boxster
