Excellent brake upgrade for 91-05 NSX models. Requires 17" wheels. The big rotor will give you more torque leverage and prevent brake fade, due to the larger thermal capacity and will keep the disc cooler and last longer.
Brake pads included in this kit are for street driving, for replacements or off-street applications please use the links below (or contact us).
Front: D304-07
Rear: D304-04
There are some modifications required for this kit (front kit only).
You will need to grind down 3mm minimum on your caliper marked in red:
