- 2 ea front CCB big rotors (420x40mm)
- 2 ea rear CCB big rotors (410x33mm)
- 2 ea front caliper adaptors
- 2 ea rear caliper adaptors
- 1 set brake pads
Feature & benefit:
- Retain stock configuration on caliper and pad.
- Direct rotor and pad swap installation.
- Replacing stock heavy iron rotors with light weight CCB rotors.
- Light weight CCB rotors can reduce the maintenance downtime & cost, and increase of mileage.
Installation:
Requires 21"+ wheels
Learn why RB-CCB rotors can perform better and last longer than OE/Brembo rotors.
