- 2 ea front CCB big rotors (432x38mm vs. OE 420x40mm)
- 2 ea rear CCB big rotors (410x30mm vs. OE 370x30mm)
- 2 ea front caliper spacers for big rotors
- 2 ea rear caliper brackets for big rotors
- 1 set ccb brake pads
Replace extremely heavy & bulky front calipers & rotors, and weak flimsy rear calipers for a more balanced and planted brake system that your RS6/RS7 deserved.
Optional adder:
- 2 ea front RB6XL 6 pot calipers
- 2 ea front caliper adaptors
- 2 ea rear RB 4 pot w/ePB calipers
- 2 ea rear caliper adaptors
Feature & benefit:
- Replacing stock heavy iron rotors with light weight CCB rotors.
- Retain stock 10/1 pot calipers and pads.
- Optional upgrade to RB 6/4 pot calipers
- Direct rotor and pad swap installation.
- Light weight CCB rotors can reduce the maintenance downtime & cost, and increase of mileage.
Installation requires 22"+ wheels
Learn why RB-CCB rotors can perform better and last longer than OE/Brembo rotors.
