Application note:
This is a front caliper kit retaining the use of stock size rotors, which along with a 2pc rotor upgrade, shall handle most of the braking tasks w/o any concern of overheating, brake fade, or losing brake. However for heavy towing and/or downhill drivings, we recommend this big brake kit to assure your Cybertruck is equipped with sufficient service factor to deal with any loads, driving, & stopping conditions.
If you still have any question or concern in choosing the proper brake option, you can contact us for advice.
Front caliper kit includes:
- 2 ea 6-Piston forged aluminum heavy duty calipers, custom made to fit OE spindle & OE rotors
- 2 ea caliper adaptors
- 1 set brake pads
Optional item:
- 2 ea front 2 pc light weight stock size rotors (350x32mm)
- 6 pot calipers are the same as our 410mm BBK for Tundra for heavy towing. but custom made for replacing OE heavy and bulky 4 pot calipers.
- The caliper kits incl. brake pads which allow you to retain the use of stock rotors, you can also upgrade to 2 pc rotors at option.
- Fits 18" wheels - Be sure to download fitment template here to double check if your aftermarket 18" wheels will fit before ordering.
Caliper comparison:
Rotor wt comparison:
ROTOR WT. COMPARISON (LBS) | FRONT | REAR | TOTAL/SIDE | TOTAL/CAR |
OE Rotor |
24.17 | 18.17 | 42.34 | 84.68 |
RB 2pc Rotor |
20.24 |
14.2 | 33.56 | 67.12 |
WT. SAVING | 3.93 | 3.97 | 7.9 | 15.8 (18.7%) |
- Front: D403-01
- Front: 2731-K
