Quick view sku: 9039-141 Brake Rotor (Drill+Slot) - TT (NON QUATTRO) REAR 99-05 MSRP: $194.70 Now: $184.97 Add to Cart Compare Quick view sku: 9080-311 Brake Rotor (Slot) 256x22mm - Audi TT 01-05 & VW Jetta GLI 03-04 (QUATTRO W/VENTED REAR) REAR MSRP: $233.20 Now: $221.54 Add to Cart Compare Quick view Brake Rotor (Drill+Slot) - TT (NON QUATTRO) REAR 99-05 Material: Alloyed Gray IronMachining: Drilled & Curved SlotSurface: EDP Coating w/cross cut grinding on friction surface MSRP: $194.70 Now: $184.97 Add to Cart Compare Quick view Brake Rotor (Slot) 256x22mm - Audi TT 01-05 & VW Jetta GLI 03-04 (QUATTRO W/VENTED REAR) REAR Material: Racing Formula Alloyed Gray Iron & Heat treatedMachining: Straight SlotSurface: EDP Coating w/cross cut grinding on friction surface MSRP: $233.20 Now: $221.54 Add to Cart Compare Compare Selected × OK
