Quick view sku: 2224-K Big Brake Kit (322x30) - Audi Front w/17Z Calipers (Caliper Casting# 20.8432.07 4A) MSRP: $2,895.20 Now: $2,750.44 Compare Quick view sku: 9045-111 Brake Rotor (Slot) - A4 QUATTRO REAR 96-01 MSRP: $224.40 Now: $213.18 Add to Cart Compare Quick view sku: 2198 RB 2 Pc Rotor (332x32) for Audi Stoptech BBK Rotor Replacement MSRP: $1,151.70 Now: $1,094.12 Choose Options Compare Quick view sku: AUD-IRK-345.330 RB 2pc Rotor Kit (345/300) for Audi S4 04-09 (P/N: 2475/2661) MSRP: $2,607.00 Now: $875.99 Choose Options Compare Quick view sku: AU-IRK-390.356 RB 2pc Rotor Kit (390/356) for Audi C7 front & Rear (P/N 2484 & 2575) MSRP: $3,100.00 Now: $2,765.00 Choose Options Compare Quick view sku: 2213 RB 2pc Rotor Pkg. (348x32) for Audi w/18Z Caliper Upgrade MSRP: $1,389.30 Now: $1,319.84 Choose Options Compare Quick view sku: 2143 RB 2pc Rotors (332x32) for Audi A4 / A6 / S4 Front with Stoptech BBK Replacement Compare Quick view sku: 2183-PU RB Aluminum Caliper Upgrade Kit for Audi S4 04-09 Front (Fits Stock 350x32 Rotors) MSRP: $1,994.30 Now: $1,894.59 Add to Cart Compare Quick view sku: 2183-K RB BBK (348x32) for Audi A4/S4 (B6/B7) Front MSRP: $3,209.80 Now: $3,049.31 Add to Cart Compare Quick view sku: 2213-K RB BBK (348x32) for Audi Front w/18Z Calipers MSRP: $3,010.70 Now: $2,860.17 Add to Cart Compare Quick view sku: 2082-K RB BBK (365x34) for Audi A4/S4 Front MSRP: $3,126.20 Now: $2,969.89 Add to Cart Compare Quick view Big Brake Kit (322x30) - Audi Front w/17Z Calipers (Caliper Casting# 20.8432.07 4A) MSRP: $2,895.20 Now: $2,750.44 Compare Quick view Brake Rotor (Slot) - A4 QUATTRO REAR 96-01 Material: Alloyed Gray IronMachining: Straight SlotSurface: EDP Coating w/cross cut grinding on friction surface MSRP: $224.40 Now: $213.18 Add to Cart Compare Quick view RB 2 Pc Rotor (332x32) for Audi Stoptech BBK Rotor Replacement This rotor has a 68.1mm registered hole diameter and 5x112mm bolt holes. Compare to Stoptech's: Performance: SAE Grade 3500 iron for high performance and durability. Ease of Use: Rotors are made for easier & simpler for assembly and disassembly. MSRP: $1,151.70 Now: $1,094.12 Choose Options Compare Quick view RB 2pc Rotor Kit (345/300) for Audi S4 04-09 (P/N: 2475/2661) Replacement rotor ring: Front: D403-03 Rear: D200-10 Note: rear rotors are 300x20mm vs. OE 300x22mm. RB rotor will still out live factory rotors. MSRP: $2,607.00 Now: $875.99 Choose Options Compare Quick view RB 2pc Rotor Kit (390/356) for Audi C7 front & Rear (P/N 2484 & 2575) Kit includes: 2 ea two-piece front rotors (390x36mm) 2 ea two-piece rear rotors (356x23 vs. 356x22mm) Brake pads (Optional) Replacement components: Front rotor rings: D601-05 Rear rotor rings: D401-06 Front pads: PD1575 Rear pads: PD1547 MSRP: $3,100.00 Now: $2,765.00 Choose Options Compare Quick view RB 2pc Rotor Pkg. (348x32) for Audi w/18Z Caliper Upgrade MSRP: $1,389.30 Now: $1,319.84 Choose Options Compare Quick view RB 2pc Rotors (332x32) for Audi A4 / A6 / S4 Front with Stoptech BBK Replacement This rotor has a 68.1mm registered hole diameter and 5x112mm bolt holes. Performance: SAE Grade 3500 iron for high performance and durability. Ease of Use: Rotor hardware are simple and easier to assemble/disassemble. Order substituted (w/3mm spacer... Compare Quick view RB Aluminum Caliper Upgrade Kit for Audi S4 04-09 Front (Fits Stock 350x32 Rotors) This Progressive Upgrade kit is intended for customers who already own RB stock replacement two piece rotors.Although the kit can also be used as a caliper upgrade for OEM or aftermarket rotors (with the same size and offset), it is highly recom MSRP: $1,994.30 Now: $1,894.59 Add to Cart Compare Quick view RB BBK (348x32) for Audi A4/S4 (B6/B7) Front MSRP: $3,209.80 Now: $3,049.31 Add to Cart Compare Quick view RB BBK (348x32) for Audi Front w/18Z Calipers NOTE: Brake pads are brake MSRP: $3,010.70 Now: $2,860.17 Add to Cart Compare Quick view RB BBK (365x34) for Audi A4/S4 Front Kit includes: 2 ea 2 pc rotors. 2 ea 4-Piston aluminum calipers 2 ea Aluminum adapters 1 Set of RB street pads MSRP: $3,126.20 Now: $2,969.89 Add to Cart Compare Compare Selected × OK
