- 2 ea. RB 6-piston calipers & adaptors
- 2 ea. RB 4-piston calipers & adaptors
- 2 ea. Front CCM rotor (410x36mm)
- 2 ea. Rear CCM rotor (390x32mm)
- 2 ea. Parking brake caliper spacers & hardware
- 1 car set brake pads (Optional)
Feature & benefit:
- Kit is made with RB 6 pot/4 pot track duty calipers (same as for McLare kits) for ultimate tracking performance and durability.
- Rotor offsets are designed about 1" wider than stock for a more planted braking at tight corners.
- Fits OE 20" wheel, wheel spacer maybe required to clear the wheel spokes.
- Retain rear OE parking brake (spacer kit included), same as our offer for Corvette C8 Z51.
- Rotors are made of continuous carbon fiber, and are directional for a more efficient cooling. (learn more)
- Rotor sizes are same as Porsche 991 GT3 pccb 410/390 (vs. OE 370/350mm) = 40mm increaes both front and rear)
- Brake pads are same as for Corvette ZR1/Camero Z28/Ferrari F458 etc. for easy sourcing at low cost.
- Brake system is designed and made by RacingBrake, the most experienced ccb brake mfgr in the performance industry.
- Front: 2R74-K
- Rear: 2R75-K
Application notes:
With proper brake pads, this kit is intended for track racing.
