- This brake system requires a rear parking brake (provided by customer) to complete the installation.
- Sample set of brake line is required from customer to fabricate.
- For initial sample kit the caliper finish (color) will be furnished as available, customer can specify the color for production order.
- Price does not include logo and screen art.
- 2 ea. Front RB6L 6-piston calipers
- 2 ea. Front CCM rotors (420x36)
- 2 ea. Front caliper adaptors
- 2 ea. Rear RB4L 4-piston calipers
- 2 ea. Rear CCM rotors (410x30)
- 2 ea. Rear caliper adaptors
- 2 ea. Parking brake adaptors (for oversizing from 360mm to 410mm)
- 1 car set street brake pads for CCM rotor
- 1 car set brake line
- Front: PD1395-360
- Rear: PD1165-360
- 2R63-K
Weight saving:
ROTOR WT. COMPARISON (LBS) | FRONT | REAR | TOTAL/SIDE | TOTAL/CAR |
OE IRON | 30 | |||
RB CCM BBK |
18.4 | |||
WT. SAVING |
Feature & benefit:
- 100% Bolt-On installation, easier to install than replacing stock iron rotors due to lighter weight.
- RB discs are made with Gen 4 CCM technology; with long (continuous) carbon fibers and angle vanes.
- CCM rotors have "Diamond hard" surface with excellent "Thermal Stability" so they will NEVER Wear*, Warp, or Crack (due to the heat). More advantageous for tracking/racing with proper brake pads.
- Runs on street or tracks w/o temperature (cold or hot weather), or water (rain or car wash) effect.
- Never rust, always looks like new.
- Literally no brake dust.
- Dramatically reduction on unsprung weight.
- Improve driving comfort.
- Inspiring braking confidence on tracks.
- Substantial reduction on maintenance cost and downtime in pad and rotor replacements.
- Save money than iron brake in the long run.
Avoid:
- Running rotor continuously above threshold temp @650F
- Running brake pad below 1/3 of the lining material (~4mm)
