Quick view sku: H045-K 2 ea. RB Light Wt Rotor Hat for Corvette ZR1/C7 Rear CCM Rotors (390mm) (Incl. Harware Kit) $1,760.00 $1,672.99 Add to Cart Compare
Quick view sku: PD-ZR1-360 [PD-ZR1-360] RB (ST600) Street Brake Pads for CCM Rotors - Corvette ZR1, Camaro Z28, Ferrari F458, McLaren etc. FRONT & REAR: (PD1395 & PD1165) - ST600 $1,078.25 $970.42 Add to Cart Compare
Quick view sku: PD1165-21 [PD1165-21] OE Corvette ZR1 Brake Pad for Rear CCM Rotors (OE# 22956256) $400.00 $380.99 Add to Cart Compare
Quick view sku: PD1165-360 [PD1165-360] RB Brake Pads for CCM Rotors - Corvette ZR1, Camaro Z28, Ferrari F458, McLaren & RB4L Calipers REAR $450.00 $427.99 Add to Cart Compare
Quick view sku: PD1165-40 [PD1165-40] RB XC-40 Sintered Brake Pad for ZR1 CCM Rotor (Rear) $766.00 $727.99 Add to Cart Compare
Quick view sku: PD1165-41 [PD1165-41] RB XC-41 Sintered Brake Pad for ZR1 CCM Rotor (Rear) $766.00 $727.99 Add to Cart Compare
Quick view sku: PD1395-21 [PD1395-21] Brembo OE#22956252: Camaro Z28, ZL1 (G6), Corvette ZR1, Ferrari F458, Land Rover, McLaren, Jeep Trackhawk, Mustang GT350, Viper ACRE & RB6L Calipers etc. Front $700.00 $665.99 Add to Cart Compare
Quick view sku: PD1395-360 [PD1395-360] RB Brake Pads for CCM Rotors: Camaro Z28, ZL1 (G6), Corvette ZR1, Ferrari F458, Land Rover, McLaren, Jeep Trackhawk, Mustang GT350, Viper ACRE & RB6L Calipers etc. Front $685.00 $650.99 Add to Cart Compare
Quick view sku: PD1395-40 [PD1395-40] RB (XC40) Sintered Pad: Camaro Z28, ZL1 (G6), Corvette ZR1, Ferrari F458, Land Rover, McLaren, Jeep Trackhawk, Mustang GT350, Viper ACRE & RB6L Calipers etc. Front $1,047.00 $994.99 Add to Cart Compare
Quick view sku: PD1395-41 [PD1395-41] RB (XC41) Sintereed Pad:Camaro Z28, ZL1 (G6), Corvette ZR1, Ferrari F458, Land Rover, McLaren, Jeep Trackhawk, Mustang GT350, Viper ACRE & RB6L Calipers etc. Front $1,047.00 $994.99 Add to Cart Compare
Quick view sku: GM-IRK-09 RB 2pc Rotor Kit (390x36/390x30) for Corvette C7 CCM Conversion to Iron (P/N 2242 & 2368) $3,675.00 $3,500.00 Compare
Quick view sku: GM-CRK-04 RB-CCB Rotor Kit (394/390) for Corvette C7 Replacment or Upgrade from OE's Chopped Carbon Fiber CCB Rotors (P/N 2C01 & 2C52) $11,900.99 Choose Options Compare
Quick view sku: RCCB-GM-05 RB-CCB System Kit (394/390) for Corvette C7 (P/N 2C01-K & 2C52-K) $15,900.99 Choose Options Compare
Quick view 2 ea. RB Light Wt Rotor Hat for Corvette ZR1/C7 Rear CCM Rotors (390mm) (Incl. Harware Kit) OE Stainless Steel Hat:RB Composite Hat:These light weight composite hats are fully compatible with OE Emergency brake. Offest is factored in on rotor hat design and will not affect rotor offset in any way. $1,760.00 $1,672.99 Add to Cart Compare
Quick view [PD-ZR1-360] RB (ST600) Street Brake Pads for CCM Rotors - Corvette ZR1, Camaro Z28, Ferrari F458, McLaren etc. FRONT & REAR: (PD1395 & PD1165) - ST600 You save 10% when buying front and rear pads together vs. purchasing separately. Here is the link if you would like to purchase individually: Front: PD1395-360 Rear: PD1165-360 $1,078.25 $970.42 Add to Cart Compare
Quick view [PD1165-21] OE Corvette ZR1 Brake Pad for Rear CCM Rotors (OE# 22956256) $400.00 $380.99 Add to Cart Compare
Quick view [PD1165-360] RB Brake Pads for CCM Rotors - Corvette ZR1, Camaro Z28, Ferrari F458, McLaren & RB4L Calipers REAR High metallic brake pads specially developed for Carbon Ceramic Rotors. Performance characteristics is comparable to Pagid RSC1 ($431) and OE Brembo. Consistent COF (Coefficient of Friction) Wider range of environmental temperature Excellent modulation... $450.00 $427.99 Add to Cart Compare
Quick view [PD1165-40] RB XC-40 Sintered Brake Pad for ZR1 CCM Rotor (Rear) 100% metallic trackable street compound for carbon ceramic rotors. $766.00 $727.99 Add to Cart Compare
Quick view [PD1165-41] RB XC-41 Sintered Brake Pad for ZR1 CCM Rotor (Rear) 100% metallic track/racing compound for carbon ceramic rotors. $766.00 $727.99 Add to Cart Compare
Quick view [PD1395-21] Brembo OE#22956252: Camaro Z28, ZL1 (G6), Corvette ZR1, Ferrari F458, Land Rover, McLaren, Jeep Trackhawk, Mustang GT350, Viper ACRE & RB6L Calipers etc. Front $700.00 $665.99 Add to Cart Compare
Quick view [PD1395-360] RB Brake Pads for CCM Rotors: Camaro Z28, ZL1 (G6), Corvette ZR1, Ferrari F458, Land Rover, McLaren, Jeep Trackhawk, Mustang GT350, Viper ACRE & RB6L Calipers etc. Front High metallic brake pads specially developed for Carbon Ceramic Rotors. Performance characteristics is comparable to Pagid RSC1 ($729) and OE Brembo. Consistent COF (Coefficient of Friction) Wider range of environmental temperature Excellent modulation... $685.00 $650.99 Add to Cart Compare
Quick view [PD1395-40] RB (XC40) Sintered Pad: Camaro Z28, ZL1 (G6), Corvette ZR1, Ferrari F458, Land Rover, McLaren, Jeep Trackhawk, Mustang GT350, Viper ACRE & RB6L Calipers etc. Front 100% metallic streetable track compound for carbon ceramic rotors. $1,047.00 $994.99 Add to Cart Compare
Quick view [PD1395-41] RB (XC41) Sintereed Pad:Camaro Z28, ZL1 (G6), Corvette ZR1, Ferrari F458, Land Rover, McLaren, Jeep Trackhawk, Mustang GT350, Viper ACRE & RB6L Calipers etc. Front 100% metallic dedicated track/racing compound for carbon ceramic rotors (not suitable for street driving) $1,047.00 $994.99 Add to Cart Compare
Quick view RB 2pc Rotor Kit (390x36/390x30) for Corvette C7 CCM Conversion to Iron (P/N 2242 & 2368) Front rotor diameter is made to 390mm (vs. OE CCM's 394) which is the brake pad actual contact dia. to avoid rusty lips on rotor edge. Brake pads included in the kit is for street driving, for off-street applications please contact us or use the links... $3,675.00 $3,500.00 Compare
Quick view RB-CCB Rotor Kit (394/390) for Corvette C7 Replacment or Upgrade from OE's Chopped Carbon Fiber CCB Rotors (P/N 2C01 & 2C52) The rotor kit is bundled with our ST600 high metallic brake agressive street pads (not for tracks) specially developed for carbon ceramic rotors. Performance characteristics is comparable to Pagid RSC1 and OE Brembo. Consistent COF... $11,900.99 Choose Options Compare
Quick view RB-CCB System Kit (394/390) for Corvette C7 (P/N 2C01-K & 2C52-K) Kit contains: 2 ea. RB 6-piston caliper 2 ea. RB 4-piston caliper 2 ea. Front CCM rotor 2 ea. Rear CCM rotor 1 car set brake pads $15,900.99 Choose Options Compare
