- 2 ea front CCB big rotors (400x38mm)
- 2 ea rear CCB stock size rotors (350x28mm)
- 1 set ccb brake pads
If rear BBK option is selected:
- 2 ea rear CCB big rotors (400x28mm) instead of stock size 350x28mm
- 2 ea RB 4 pot ePB calipers
- 2 ea caliper adaptors for BBK
Feature & benefit:
- Retain stock caliper and pad.
- Direct rotor and pad swap installation.
- Replacing stock heavy iron rotors with light weight CCB rotors.
- Light weight CCB rotors can increase of mileage & reduce the maintenance downtime/cost.
Installation:
Requires 20"+ wheels
Learn why RB-CCB rotors can perform better and last longer than OE/Brembo rotors.
