Quick view sku: 9045-111 Brake Rotor (Slot) - A4 QUATTRO REAR 96-01 MSRP: $224.40 Now: $213.18 Add to Cart Compare Quick view sku: 2198 RB 2 Pc Rotor (332x32) for Audi Stoptech BBK Rotor Replacement MSRP: $1,151.70 Now: $1,094.12 Choose Options Compare Quick view sku: AU-IRK-390.356 RB 2pc Rotor Kit (390/356) for Audi C7 front & Rear (P/N 2484 & 2575) MSRP: $3,100.00 Now: $2,765.00 Choose Options Compare Quick view sku: 2173 RB 2pc Rotors (310x25) for VW MK5, MK6 & MK7 (non-R32) & Audi A3 06-10 Front MSRP: $963.60 Now: $915.42 Add to Cart Compare Quick view sku: 2183-PU RB Aluminum Caliper Upgrade Kit for Audi S4 04-09 Front (Fits Stock 350x32 Rotors) MSRP: $1,994.30 Now: $1,894.59 Add to Cart Compare Quick view sku: 2183-K RB BBK (348x32) for Audi A4/S4 (B6/B7) Front MSRP: $3,209.80 Now: $3,049.31 Add to Cart Compare Quick view sku: 2082-K RB BBK (365x34) for Audi A4/S4 Front MSRP: $3,126.20 Now: $2,969.89 Add to Cart Compare Quick view sku: 2190-K RB Brake Kit (330x30) for VW MK5/MK6 04-11 & Audi A3 B6/B7 06-10 Front MSRP: $2,438.70 Now: $2,316.77 Choose Options Compare Quick view sku: 2173-K RB Caliper Kit (310x25=Stock Size) for VW MK5/6/7 & Audi A3 B6/B7 Front MSRP: $2,380.00 Now: $2,260.00 Choose Options Compare Quick view Brake Rotor (Slot) - A4 QUATTRO REAR 96-01 Material: Alloyed Gray IronMachining: Straight SlotSurface: EDP Coating w/cross cut grinding on friction surface MSRP: $224.40 Now: $213.18 Add to Cart Compare Quick view RB 2 Pc Rotor (332x32) for Audi Stoptech BBK Rotor Replacement This rotor has a 68.1mm registered hole diameter and 5x112mm bolt holes. Compare to Stoptech's: Performance: SAE Grade 3500 iron for high performance and durability. Ease of Use: Rotors are made for easier & simpler for assembly and disassembly. MSRP: $1,151.70 Now: $1,094.12 Choose Options Compare Quick view RB 2pc Rotor Kit (390/356) for Audi C7 front & Rear (P/N 2484 & 2575) Kit includes: 2 ea two-piece front rotors (390x36mm) 2 ea two-piece rear rotors (356x23 vs. 356x22mm) Brake pads (Optional) Replacement components: Front rotor rings: D601-05 Rear rotor rings: D401-06 Front pads: PD1575 Rear pads: PD1547 MSRP: $3,100.00 Now: $2,765.00 Choose Options Compare Quick view RB 2pc Rotors (310x25) for VW MK5, MK6 & MK7 (non-R32) & Audi A3 06-10 Front Replacement rotor rings: D200-06-381 MSRP: $963.60 Now: $915.42 Add to Cart Compare Quick view RB Aluminum Caliper Upgrade Kit for Audi S4 04-09 Front (Fits Stock 350x32 Rotors) This Progressive Upgrade kit is intended for customers who already own RB stock replacement two piece rotors.Although the kit can also be used as a caliper upgrade for OEM or aftermarket rotors (with the same size and offset), it is highly recom MSRP: $1,994.30 Now: $1,894.59 Add to Cart Compare Quick view RB BBK (348x32) for Audi A4/S4 (B6/B7) Front MSRP: $3,209.80 Now: $3,049.31 Add to Cart Compare Quick view RB BBK (365x34) for Audi A4/S4 Front Kit includes: 2 ea 2 pc rotors. 2 ea 4-Piston aluminum calipers 2 ea Aluminum adapters 1 Set of RB street pads MSRP: $3,126.20 Now: $2,969.89 Add to Cart Compare Quick view RB Brake Kit (330x30) for VW MK5/MK6 04-11 & Audi A3 B6/B7 06-10 Front Kit includes: 2 ea RB 4 pot calipers 2 ea caliper adaptors 2 ea light weight two piece rotors 1 set brake pads Replacement rotor rings: D305-02 Replacement brake pads: PD647-391 MSRP: $2,438.70 Now: $2,316.77 Choose Options Compare Quick view RB Caliper Kit (310x25=Stock Size) for VW MK5/6/7 & Audi A3 B6/B7 Front Kit includes: 2 ea RB4045N calipers+ 2 ea M10x1.0 banjo bolts for RB caliper install (vs. OE M10x1.25) 2 ea caliper adaptors 2 ea light weight two piece rotors* (OD is made to 310mm to eliminate undesierable rusty lip like OE's 312mm) 1 set brake... MSRP: $2,380.00 Now: $2,260.00 Choose Options Compare Compare Selected × OK
