- 2 ea 2 pc rotors 390x28mm (vs. OE 375x22)
- 2 ea Integrated calipers (4+1 pistons) & actuators
- 2 ea caliper adaptors
- 1 set brake pads
- 1 set brake lines
Installation (brief steps):
- Retract brake pad to loosen up the pad/rotor.
- Separate e-motor from the caliper.
- Disconnet hydraulic hoses.
- Remove OE caliper from the spindle.
- Replace OE rotor with the new 2 pc rotor.
- Attache OE e-motor to the new caliper actuator.
- Reconnect hydraulic hoses to the new calipers.
- Properly torque all fasteners.
- Bleed the system.
Advantage of RB4-ePB caliper:
vs. OE Single piston caliper:
OE | RB | Advantage | |
Braking & parking | 1 system | 2 separate systems | More assured for individual functionality. |
Performance | Floating (piston & bracket) | Fixed (piston to piston) | Immediate pedal response |
Apperance | Typical cast iron caliper | Motorsports aluminum caliper | Higher visual impact |
Weight Info:
Replacement components:
