Quick view sku: 2612 RB 2pc Rotor (380) for Ford Mustang Shelby GT350 Rear (For Racing Only, Rear Drum Brake Disabled) $1,100.00 $1,045.00 Add to Cart Compare
Quick view sku: 2611 RB 2pc Rotor (380x36mm) Downsized from OE's 394x36mm for 2016+ Ford Mustang GT350 Front Fits 18" Wheels (Caliper Modification is Required) $1,263.00 $1,199.85 Add to Cart Compare
Quick view sku: 2568 RB 2pc Rotor for 2016+ Ford Mustang Shelby GT350 Front $1,495.00 $1,420.25 Add to Cart Compare
Quick view sku: FOR-IRK-07 RB 2pc Rotor Kit (395/380) for Ford Mustang Shelby GT350 2016+ Front & Rear (P/N 2568 & 2569) $2,865.83 $2,729.99 Choose Options Compare
Quick view sku: 2611a RB 2pc Rotors (380x36mm) & Caliper Adaptor Kit for GT350 Caliper for Focus RS Front $2,526.00 $2,399.70 Add to Cart Compare
Quick view sku: FOR-IRP-10 RB BBK (380x36/380x30) for Ford Mustang GT350 (2611-K, 2612-K). -For Rear Rotor Kit See Our Disclaimer Under Description- $6,888.43 $6,560.99 Choose Options Compare
Quick view sku: FOR-IRP-11 RB BBK (395/380) for Ford Mustang Shelby GT350 2016+ Front & Rear (P/N 2568-K & 2569-K) $6,550.81 $6,240.99 Choose Options Compare
Quick view sku: 2611-K RB Caliper Brake Kit (380x36mm) Downsized from OE's 394x36mm for 2016+ Ford Mustang GT350 Front Fits 18" Wheels $3,579.00 $3,400.05 Add to Cart Compare
Quick view sku: CC-04K RB Hardware Kit for Ford GT350 Front 6 Pot Caliper Pad Hold Down Spring (Picture Only Showing After Assembly, OE Spring is Not Included) $42.00 $39.90 Add to Cart Compare
Quick view RB 2pc Rotor (380) for Ford Mustang Shelby GT350 Rear (For Racing Only, Rear Drum Brake Disabled) $1,100.00 $1,045.00 Add to Cart Compare
Quick view RB 2pc Rotor (380x36mm) Downsized from OE's 394x36mm for 2016+ Ford Mustang GT350 Front Fits 18" Wheels (Caliper Modification is Required) $1,263.00 $1,199.85 Add to Cart Compare
Quick view RB 2pc Rotor for 2016+ Ford Mustang Shelby GT350 Front Rotor Comparison: $1,495.00 $1,420.25 Add to Cart Compare
Quick view RB 2pc Rotor Kit (395/380) for Ford Mustang Shelby GT350 2016+ Front & Rear (P/N 2568 & 2569) ROTOR WT. COMPARISON (LBS) per rotor FRONT REAR OE 30.3 19.1 RB 29.3 17 Brake pads included in the kit is for street driving, for off street applications please click the link below for additional choices: Brake pad Selection Guide Front:... $2,865.83 $2,729.99 Choose Options Compare
Quick view RB 2pc Rotors (380x36mm) & Caliper Adaptor Kit for GT350 Caliper for Focus RS Front $2,526.00 $2,399.70 Add to Cart Compare
Quick view RB BBK (380x36/380x30) for Ford Mustang GT350 (2611-K, 2612-K). -For Rear Rotor Kit See Our Disclaimer Under Description- This brake kit is specially made for track racing that can possibly run on 18" wheels (download wheel fitment diagram below to check), as a result the rear rotor hat can't accomondate the OE drum brake which must be removed or deleted in order to install... $6,888.43 $6,560.99 Choose Options Compare
Quick view RB BBK (395/380) for Ford Mustang Shelby GT350 2016+ Front & Rear (P/N 2568-K & 2569-K) Brake pads included in the kit is for street driving, for off-street applications please use the links below.Front: PD1395Rear: PD592Brake pad Selection Guide Replacement disk: Front: D602-04Rear: 1503-11 $6,550.81 $6,240.99 Choose Options Compare
Quick view RB Caliper Brake Kit (380x36mm) Downsized from OE's 394x36mm for 2016+ Ford Mustang GT350 Front Fits 18" Wheels Kit contains: 2 ea two piece rotors (380x36mm) 2 ea RB 6 pot heavy duty calipers (direct mount to OE spindle) 1 set street pads $3,579.00 $3,400.05 Add to Cart Compare
Quick view RB Hardware Kit for Ford GT350 Front 6 Pot Caliper Pad Hold Down Spring (Picture Only Showing After Assembly, OE Spring is Not Included) Kit Includes: 4 ea Aluminum tube insert for 1 caliper. Order qty 2 for 2 calipers.This exclusive RB hardware kit can convert GT350 OE caliper to be able to use more common $42.00 $39.90 Add to Cart Compare
