Quick view sku: 9081-111 RB 1pc rotor kit (290x10mm) w/170mm drum - Subaru Rear 09-13 MSRP: $271.70 Now: $258.12 Add to Cart Compare Quick view sku: 2312 RB 2 pc Rotor (294x24) for Scion FRS, Subaru BRZ & WRX (w/Dual Piston Caliper) Front MSRP: $867.90 Now: $824.51 Choose Options Compare Quick view sku: 2014-K RB BBK (322x25) for Subaru BRZ, Scion FR-S, GT86 Front MSRP: $2,035.00 Now: $1,933.25 Add to Cart Compare Quick view sku: AD201 RB Caliper Adaptor for 04+ Subaru Front (Price for 1) - Pic. is for ILLUSTRATION ONLY and does not represent the actual part MSRP: $495.00 Now: $235.12 Add to Cart Compare Quick view sku: BRZ-IRP-01 Save 10% on RB BBK (332/330) Combo Kit for Subaru WRX (2008+)/BRZ; Toyota GT86; Scion FR-S Front & Rear (P/N 2567-K & 2315-K) MSRP: $3,885.00 Now: $3,690.00 Compare SALE Quick view sku: BRZ-IRP-02 Save 10% on RB BBK/OE Caliper kit (322/316) for Subaru BRZ, Scion FR-S, GT86 (2014-K & 2060-K) MSRP: $2,579.00 Was: $2,450.05 Now: $2,321.10 Choose Options Compare Quick view RB 1pc rotor kit (290x10mm) w/170mm drum - Subaru Rear 09-13 Material: Alloyed Gray IronMachining: Straight SlotSurface: EDP Coating w/cross cut grinding on friction surface Rotor wt: 10.7 lbs MSRP: $271.70 Now: $258.12 Add to Cart Compare Quick view RB 2 pc Rotor (294x24) for Scion FRS, Subaru BRZ & WRX (w/Dual Piston Caliper) Front Rotor Material: Racing Formula Alloyed Gray Iron & Heat treated Machining: Open Slot Surface: EDP Coating w/cross cut grinding on surface. Replacement components: Brake pads: PD647 Rotor rings: D200-03 MSRP: $867.90 Now: $824.51 Choose Options Compare Quick view RB BBK (322x25) for Subaru BRZ, Scion FR-S, GT86 Front Replacement components: brake pads: PD647 rotor rings: D214-01 rotor hats: H801-05 MSRP: $2,035.00 Now: $1,933.25 Add to Cart Compare Quick view RB Caliper Adaptor for 04+ Subaru Front (Price for 1) - Pic. is for ILLUSTRATION ONLY and does not represent the actual part Eligible for customers who already owned RB caliper kits for the listed applications only. Purchase eligibility is subject to verfication. MSRP: $495.00 Now: $235.12 Add to Cart Compare Quick view Save 10% on RB BBK (332/330) Combo Kit for Subaru WRX (2008+)/BRZ; Toyota GT86; Scion FR-S Front & Rear (P/N 2567-K & 2315-K) Kit Includes: 2 ea front 4 pot calipers 2 ea lightweight 2 pc rotors (332x26mm) 2 ea rear 2 pot calipers 2 ea lightweight 2 pc rotors (330x22mm built with drum brake 100% compatible with OE) 1 car set brake pads 1 set SS brake lines Replacement... MSRP: $3,885.00 Now: $3,690.00 Compare SALE Quick view Save 10% on RB BBK/OE Caliper kit (322/316) for Subaru BRZ, Scion FR-S, GT86 (2014-K & 2060-K) Replacement components Brake pads: Front: PD647 Rear: PD770 Front rotor rings: D214-01 Rear 1pc: 9160-141 MSRP: $2,579.00 Was: $2,450.05 Now: $2,321.10 Choose Options Compare Compare Selected × OK
