Quick view sku: 9039-141 Brake Rotor (Drill+Slot) - TT (NON QUATTRO) REAR 99-05 $177.00 $168.99 Add to Cart Compare
Quick view sku: 9080-311 Brake Rotor (Slot) - TT (QUATTRO W/VENTED REAR) REAR 01-05 $212.00 $201.99 Add to Cart Compare
Quick view sku: 2353-K RB 2pc Rotor BBK (308x22) for MK4 VW Golf / Audi TT Rear Upgrade from 256mm $850.00 $812.99 Add to Cart Compare
Quick view sku: 2044 RB 2pc Rotors (310x25) for Audi 2000-06 TT, VW 2002-03 Golf, VW 2004-05 Jetta Front $876.00 $832.20 Add to Cart Compare
Quick view Brake Rotor (Drill+Slot) - TT (NON QUATTRO) REAR 99-05 Material: Alloyed Gray IronMachining: Drilled & Curved SlotSurface: EDP Coating w/cross cut grinding on friction surface $177.00 $168.99 Add to Cart Compare
Quick view Brake Rotor (Slot) - TT (QUATTRO W/VENTED REAR) REAR 01-05 Material: Racing Formula Alloyed Gray Iron & Heat treatedMachining: Straight SlotSurface: EDP Coating w/cross cut grinding on friction surface $212.00 $201.99 Add to Cart Compare
Quick view RB 2pc Rotor BBK (308x22) for MK4 VW Golf / Audi TT Rear Upgrade from 256mm Kit includes the following (Note OE calipers are not included): 2 ea. Rear RB center mount light weight 2pc rotors 2 ea. Aluminum alloy caliper adaptors w/mounting hardware Replacement rotor ring: D200-07 $850.00 $812.99 Add to Cart Compare
Quick view RB 2pc Rotors (310x25) for Audi 2000-06 TT, VW 2002-03 Golf, VW 2004-05 Jetta Front Rotor Kit Includes: 2 ea. Front two piece rotor - Fully assembled for a 100% bolt on installation. $876.00 $832.20 Add to Cart Compare
