Quick view sku: PD1867-391A [PD1867-391A] Brake Pads - Toyota Supura MK5 (2020+) & BMW Z4 (2018+) Front $290.00 $275.50 Add to Cart Compare
Quick view sku: PD2220-391A [PD2020-391A] Brake Pads - Toyota Supura MK5 (2020+) & BMW Z4 (2018+)Rear $250.00 $237.50 Add to Cart Compare
Quick view sku: 2654 RB 2pc Rotor Kit (345x24) for Supra MK5 & BMW Z4 19+ Rear (P/N 2654) - Does not fit model w/Gray Calipers $990.00 $940.50 Choose Options Compare
Quick view sku: 2653 RB 2pc Rotor Kit (345x36) for Supra MK5 & BMW Z4 19+ Front $1,050.00 $997.50 Choose Options Compare
SALE Quick view sku: 2656-K RB BBK (370x24) Rear OE Caliper BBK for Supra (2020+) MK 5 $1,700.00 $1,535.00 Choose Options Compare
Quick view sku: 2657-K RB Caliper BBK (380x34mm) for Supra MK5 Front $4,100.00 $3,895.00 Choose Options Compare
Quick view [PD1867-391A] Brake Pads - Toyota Supura MK5 (2020+) & BMW Z4 (2018+) Front Consistent COF (Coefficient of Friction) Wider range of environmental temperature Excellent modulation Very low dust No squeak Highly durable Caution: This compound is intended for street (spirited) driving only, and is NOT for track/racing... $290.00 $275.50 Add to Cart Compare
Quick view [PD2020-391A] Brake Pads - Toyota Supura MK5 (2020+) & BMW Z4 (2018+)Rear Consistent COF (Coefficient of Friction) Wider range of environmental temperature Excellent modulation Very low dust No squeak Highly durable Caution: This compound is intended for street (spirited) driving only, and is NOT for track/racing... $250.00 $237.50 Add to Cart Compare
Quick view RB 2pc Rotor Kit (345x24) for Supra MK5 & BMW Z4 19+ Rear (P/N 2654) - Does not fit model w/Gray Calipers Replacement rotor ring: D404-02 Replacement brake pad: PD2221 ROTOR WT. (LBS) FRONT REAR TOTAL OE 27.65 18.52 47.2/SIDE RB 22.13 17 39.1/SIDE SAVING 5.52 1.52 7.04/SIDE SAVING 11.4 3.04 14.08/CAR $990.00 $940.50 Choose Options Compare
Quick view RB 2pc Rotor Kit (345x36) for Supra MK5 & BMW Z4 19+ Front The brake pads included in the car kit are for street use, for off street application other compounds are available:Front: PD1867Rear: PD2221 Replacement rotor rings:Front: D408-05Rear: D404-02 ROTOR WT. (LBS) FRONT REAR TOTAL OE 27.65 18... $1,050.00 $997.50 Choose Options Compare
SALE Quick view RB BBK (370x24) Rear OE Caliper BBK for Supra (2020+) MK 5 This rear BBK is exclusively developed by RB for upgrading your rear rotors to 370x24mm (from OE 345x24mm) with one solid piece extended bracket for an instant track duty BBK. 19" wheels are required to install the kit. Kit contains: 2 ea - Two piece... $1,700.00 $1,535.00 Choose Options Compare
Quick view RB Caliper BBK (380x34mm) for Supra MK5 Front Kit contains: 2 ea Two-piece center-mount rotors. 2 ea 6-Piston aluminum calipers 2 ea Adapters 1 Set of RB street performance brake pads Replacement rotor ring: D501-04 Replacement brake pads: PD1666 Wheel fitment template: 2657-K $4,100.00 $3,895.00 Choose Options Compare
