Quick view sku: 2584 RB 2pc Rotor (420x38 vs. CCB 420x40) for Audi RS7 Front (CCB to Iron Convesion) $1,785.00 $1,698.00 Choose Options Compare
Quick view sku: 2585 RB 2pc Rotor Kit (370x30) for Audi RS7 (CCB to Iorn) $1,324.10 $1,257.90 Pre-Order Now Compare
Quick view sku: AUD-IRK-03 RB 2pc Rotor Kit (390/356) for Audi RS7 Non-CCB (P/N 2484 & 2575) $2,921.00 $2,774.99 Choose Options Compare
Quick view sku: AUD-IRK-08 RB 2pc Rotor Kit (420/370) for Audi RS7 CCM to Iron Conversion (P/N 2584 & 2585) $3,684.00 $3,499.80 Compare
Quick view sku: 2575 RB 2pc Rotors (356x24) for Audi A8, S6/7/8, Q3, RS7 (2013+) Rear (OE=356x22) $1,316.00 $1,250.20 Add to Cart Compare
Quick view sku: 2484 RB 2pc Rotors for Audi RS7 (Non CCB) Front $1,895.00 $1,800.25 Choose Options Compare
Quick view sku: AUD-CIR-01 RB-CCB Front (390x34)/Iron Rear (356x24) Rotor Kit for Audi RS7 (P/N 2C10 & 2575) $7,895.00 $7,500.25 Compare
Quick view RB 2pc Rotor (420x38 vs. CCB 420x40) for Audi RS7 Front (CCB to Iron Convesion) Replacement rotor ring: D604-01 Replacement brake pad: (For iron rotor convering from CCB) PD1530-391 $1,785.00 $1,698.00 Choose Options Compare
Quick view RB 2pc Rotor Kit (370x30) for Audi RS7 (CCB to Iorn) Replacement Rotor Ring D501-03 $1,324.10 $1,257.90 Pre-Order Now Compare
Quick view RB 2pc Rotor Kit (390/356) for Audi RS7 Non-CCB (P/N 2484 & 2575) This kit includes: 2ea two-piece front rotors 2ea two-piece rear rotors 1 set of front pads (rear pads are not available) Brake pads included in the kit is for street driving, for off-street applications please use the links below. Front: PD1291 Rear:... $2,921.00 $2,774.99 Choose Options Compare
Quick view RB 2pc Rotor Kit (420/370) for Audi RS7 CCM to Iron Conversion (P/N 2584 & 2585) $3,684.00 $3,499.80 Compare
Quick view RB 2pc Rotors (356x24) for Audi A8, S6/7/8, Q3, RS7 (2013+) Rear (OE=356x22) Replacement Rotor Ring D502-04 Product Wt: 13.95 lbs $1,316.00 $1,250.20 Add to Cart Compare
Quick view RB-CCB Front (390x34)/Iron Rear (356x24) Rotor Kit for Audi RS7 (P/N 2C10 & 2575) Kit contains: 2 ea - Front CCB rotors (brake pads are available as option) 2 ea - Rear Iron rotors (brake pads are not available) Rotors are made to the same offset as OE for "plug and play" installation. Requires no modification to OE calipers. $7,895.00 $7,500.25 Compare
