- 2 ea front two piece light weight high performance rotors (432x34mm)
- 2 ea 6 pot heavy duty aluminum calipers
- 2 ea front caliper adaptors
- 2 ea rear two piece light weight high performance rotors (410x30mm)
- 2 ea 4 pot heavy duty aluminum calipers
- 2 ea rear caliper adaptors
- 1 car set brake pads
- 1 car set stainless stell braied brake lines
Rotor wt info:
- Front rotor (432x34mm): 28 lbs
- Rear rotor (410x30mm): 21.5 lbs
Brake pad replacement:
- Front: PD1291/PD1395A
- Rear: PD1165
Installation:
Require 21" wheels to install the kit, however we recommend downloading the following template (need to check on front kit) to confirm the wheel clearance.
