Created with Sketch. Created with Sketch.
RB CCM Rotors Compared to Others
CCM Disc Design and Construction:
Conventional disc design (Brembo & Surface Transforms):
Rotor are non-directional (Left and right are the same)
Brembo (OEM) - Chopped (Short) Carbon Fiber w/Straight cooling vanes
 Surface Transforms - Continuous (Long) Carbon Fibers w/Straight cooling vanes
RB's Discs - Continuous (Long) Carbon Fibers w/Angle cooling vanes
Disc Design, Material & Finish Comparison:
RB - Continuous (Long) Fiber, Angle Cooling Vanes, Fully Machined.
All hardware are designed and made by our own tooling (M6 w/Allen hex head vs. OE M5 w/H head) for easy assembly & disassembly, and maintenance.
Rotor Hats
RB hats are machined from forged 6061-T6 aluminum (vs. extruded) - Higher in strength and structure consistency.
Our hat design is programmed to generate "STEPS" to increase the heat path, which provides more cooling surface and extend the heat transfer time to the hub bearing from the disc - A True HAT that's more efficient in cooling, unlike competitions' design with a tapered contour "BELL" which has more immediate heat transfer with less cooling area.
Competition's BELL:
