Quick view sku: 2120-K 13" Big Brake Kit for Infiniti G37/Nissan 370Z Front $2,216.00 $2,105.20 Add to Cart Compare
Quick view sku: 2035-K Big Brake Kit - 350Z/G35/M35 REAR 03-06 $2,592.00 $2,462.40 Add to Cart Compare
Quick view sku: 2001-K Big Brake Kit (OE Caliper, Open Slot) - Infiniti G35 (non-Brembo) & Nissan 350Z (non-Brembo) FRONT $690.00 $655.50 Add to Cart Compare
Quick view sku: 2045-K Big Brake Kit (OE Caliper, Slot) - MAXIMA FRONT 00-03 $1,307.00 $1,241.99 Add to Cart Compare
Quick view sku: 2048-K Big Brake Kit (OE Caliper, Slot) - MAXIMA FRONT 00-03-1581023350 $710.00 $674.99 Add to Cart Compare
Quick view sku: 2335-K Big Brake Kit - 240SX / 300ZX 13" FRONT $1,749.00 $1,661.99 Add to Cart Compare
Quick view sku: 2319-K Big Brake Kit - 300ZX (or 240SX*) Rear 13" Rotor Kit $1,281.00 $1,216.99 Add to Cart Compare
Quick view sku: 2271-K Big Brake Kit - Titan FRONT 04-07 (355x32mm) $2,918.00 $2,772.10 Add to Cart Compare
Quick view sku: NIS-IRP-01 RB 13" BBK for G35/350Z Front and Rear (P/N 2027-K & 2311-K) $3,568.00 $3,389.60 Compare
Quick view 13" Big Brake Kit for Infiniti G37/Nissan 370Z Front This kit include $2,216.00 $2,105.20 Add to Cart Compare
Quick view Big Brake Kit - 350Z/G35/M35 REAR 03-06 Learn why RB Aluminum caliper kits are different from others. This kit includes: 2 Two-piece center-mount rotors 2 4-Piston calipers $2,592.00 $2,462.40 Add to Cart Compare
Quick view Big Brake Kit (OE Caliper, Open Slot) - Infiniti G35 (non-Brembo) & Nissan 350Z (non-Brembo) FRONT This Kit Includes: 2 ea. 13" Big alloyed two-piece center-mount rotors 2 ea. Extended high strength brackets (CBN01-M14 x 1.5) $690.00 $655.50 Add to Cart Compare
Quick view Big Brake Kit (OE Caliper, Slot) - MAXIMA FRONT 00-03 This kit will increase from your stock size rotor of 296x24 to 324x24. This Kit Includes: 2 ea. 13" Big alloyed two-piece center-mount rotors 2 ea. $1,307.00 $1,241.99 Add to Cart Compare
Quick view Big Brake Kit (OE Caliper, Slot) - MAXIMA FRONT 00-03-1581023350 This Kit Includes: 2 ea. Alloyed one-piece rotors (9173-111) 2 ea. Extended high strength brackets (CBN01A - M12 x 1.25) Replacement ComponentsOne-piece rotor: $710.00 $674.99 Add to Cart Compare
Quick view Big Brake Kit - 300ZX (or 240SX*) Rear 13" Rotor Kit *240SX has no rear drum brake so it's required to convert the rear to 300ZX (w/drum brake) in order to retain the emergency brake functionality.This $1,281.00 $1,216.99 Add to Cart Compare
Quick view Big Brake Kit - Titan FRONT 04-07 (355x32mm) This big brake upgrade fits the following Infiniti/Nissan models and requires 18" wheels. $2,918.00 $2,772.10 Add to Cart Compare
Quick view Brake Kit - Infiniti / Nissan Front 03-11 This kit fits: Infinti EX35 (2008-11)Infinti FX35 (2003-05)Infinti FX45 (2003-05)Infinti G35 non Sport (2005-08)Infinti G37X (2009-11) $2,018.00 $1,917.10 Compare
Quick view INFINITI / NISSAN FRONT Bracket These brackets allow your INFINITI / NISSAN front calipers to use 13" rotors. The brackets are made of high strength ductile iron. $220.00 $209.00 Compare
Quick view RB 13" BBK for G35/350Z Front and Rear (P/N 2027-K & 2311-K) This kit includes: 2 ea. RB 4-Piston front caliper 2 ea. RB 2-Piston rear caliper 2 ea. Front RB 2-pc rotors 2 ea. Rear RB 2-pc rotors $3,568.00 $3,389.60 Compare
