Rear rotor installation requires trimming the lip of backing plate to avoid interference w/two piece rotor harware.
It is requiried to remove the REAR pad springs which, not only do they serve no purpose but they create noise.
RB rear rotor hats are made with light weight aluminum sheel with iron sleeve insert for the rear emergeny brake - 100% compatible with OE rear brake.
Reference reading about the rear two piece rotors with drum (emergency/parking) brake:
Front: D402-01-351
Rear: D308-04-351
Replacement brake pads
