Quick view sku: PD-ZR1-360 [PD-ZR1-360] Brake Pads for CCM Rotors - Corvette ZR1, Camaro Z28, Viper ACRE, Ferrari F458/California & 488, Alfa Rome, Nissan GT-R (w/RB rotors) & RB 6/4 Caliper Kit - FRONT & REAR: (PD1395 & PD1165) MSRP: $1,110.00 Now: $1,055.00 Choose Options Compare Quick view sku: PD1165-21 [PD1165-21] OE Corvette ZR1 Brake Pad for Rear CCM Rotors (OE# 22956256) MSRP: $440.00 Now: $418.00 Add to Cart Compare Quick view sku: GM-CRK-01 GM/Brembo CCB Brake Kit (394/390) for Camaro G5 (10-15) & CTSV V2 Upgrade (PN: 2C38 & 2C86) MSRP: $14,500.00 Now: $13,800.00 Choose Options Compare Quick view sku: GM-IRK-11 RB 2pc Rotor Kit (394/390) CCM Conversion to Iron rotors for Camaro Z/28 2012+ (P/N 2381 & 2382) MSRP: $3,843.40 Now: $3,651.23 Add to Cart Compare Quick view sku: H056-K RB Light Wt Rotor Hat for Camaro G5 Z28 Rear & G6 Upgrade to CCM Rotors (390x32mm) w/Z28 Calipers only - Not compatible with G6 Rear Calipers (2 ea. Incl. Hardware Set) MSRP: $1,936.00 Now: $1,839.20 Add to Cart Compare Quick view sku: CR20 RB-CCB Disc (390x32mm)-Replacing Corvette ZR1 Z07 & Camaro Z28 Rear Rotors - Price per pair MSRP: $4,785.00 Now: $4,545.75 Add to Cart Compare Quick view sku: CR32 RB-CCB Disc (394x36mm) - Discs are made directional (Price per Pair - 1 Left, 1 Right) MSRP: $5,455.00 Now: $5,180.00 Add to Cart Compare Quick view sku: RCCB-GM-02 RB-CCB System Kit (394/390) for Camaro G5 & Cadillac V2 Upgrade (P/N 2C38-K & 2C83-K) MSRP: $16,500.00 Now: $15,675.00 Choose Options Compare Quick view [PD-ZR1-360] Brake Pads for CCM Rotors - Corvette ZR1, Camaro Z28, Viper ACRE, Ferrari F458/California & 488, Alfa Rome, Nissan GT-R (w/RB rotors) & RB 6/4 Caliper Kit - FRONT & REAR: (PD1395 & PD1165) Installation Note: For Ford GT350 6 pot calipers installation it requires a hardware kit (included on request) to create proper tension from the hold down spring to the brake pads to avoid rattling. Brembo OE ZR1 brake pad dimension flow as seen on... MSRP: $1,110.00 Now: $1,055.00 Choose Options Compare Quick view [PD1165-21] OE Corvette ZR1 Brake Pad for Rear CCM Rotors (OE# 22956256) Available on Amazon click here: MSRP: $440.00 Now: $418.00 Add to Cart Compare Quick view GM/Brembo CCB Brake Kit (394/390) for Camaro G5 (10-15) & CTSV V2 Upgrade (PN: 2C38 & 2C86) Kit contains: 2 ea. Front Z28 6-piston calipers 2 ea. Rear Z28 4-piston calipers 2 ea. Front CCM rotors - OE Brembo made of chopped (short) carbon fibers 2 ea. Rear CCM rotors - OE Brembo made of chopped (short) carbon fibers 1 car set street pads 1 car... MSRP: $14,500.00 Now: $13,800.00 Choose Options Compare Quick view RB 2pc Rotor Kit (394/390) CCM Conversion to Iron rotors for Camaro Z/28 2012+ (P/N 2381 & 2382) Kit includes: 2 ea front rotors 2 ea rear rotors 1 car set brake pads. Replacement brake pads: Front: PD1395Rear: PD1165 Rotor replacement ring: Front: D602-01Rear: D601-09 MSRP: $3,843.40 Now: $3,651.23 Add to Cart Compare Quick view RB Light Wt Rotor Hat for Camaro G5 Z28 Rear & G6 Upgrade to CCM Rotors (390x32mm) w/Z28 Calipers only - Not compatible with G6 Rear Calipers (2 ea. Incl. Hardware Set) OE Stainless Steel Hat:RB Composite Hat:CCM Rotor Assembled with OE Hat:<img MSRP: $1,936.00 Now: $1,839.20 Add to Cart Compare Quick view RB-CCB Disc (390x32mm)-Replacing Corvette ZR1 Z07 & Camaro Z28 Rear Rotors - Price per pair Discs are designed and made with long and continuours carbon fibers which is stronger and more durable than Brembo's chopped fiber. Dimensions are fully compatible with OE CCM rotor components (Ref. OEM# 20681826) allowing you to build your own CCM... MSRP: $4,785.00 Now: $4,545.75 Add to Cart Compare Quick view RB-CCB Disc (394x36mm) - Discs are made directional (Price per Pair - 1 Left, 1 Right) This rotor ring is made to the same dimensions as ZR1 (C6) and Camaro Z28 Front so it can be used as a replacement upgrade to OE's chopped carbon for improved strength and durability. Note: Necessary hardware kits are not included but can be purchased... MSRP: $5,455.00 Now: $5,180.00 Add to Cart Compare Quick view RB-CCB System Kit (394/390) for Camaro G5 & Cadillac V2 Upgrade (P/N 2C38-K & 2C83-K) Kit contains: 2 ea. RB 6-piston caliper 2 ea. RB 4-piston caliper 2 ea. Front CCM rotor built with RB long (continuous) carbon fibers 2 ea. Rear CCM rotor built with RB long (continuous) carbon fibers 1 car set Caliper adaptors & hardware 1 car set... MSRP: $16,500.00 Now: $15,675.00 Choose Options Compare Compare Selected × OK
