- 2 ea front CCM rotors (380x34 vs. OE 360x32)
- 2 ea rear CCM rotors (350x28=Stock)
- 1 set front caliper spacers (for installing the big rotors)
- 1 car set CCB brake pads (optional)
- Rotors are made for a 100% direct bolt-on installation (Quadrifoglio models only), they will fit OE 6 pot front and 4 pot rear calipers, and the parking brake w/o any modification.
- Unlike converting to OE CCB which requires to swap the rear spindle for 360x28 rotor, our rear CCB rotors are made 100% compatible to your exisitng iron brake so no spindle or calipers swap is required.
- Save time and money in acquiring and swapping spindle/calipers.
- Easy installation - Easier than replacing stock iorn rotors becasue of light weight.
- Stay in stock configuration, swap ccb and iron rotors back and forth as you need.
- Lower your maintenance down time and replacement cost.
- More brake pad contact surface. (65mm pad depth vs oe 55mm)
- Front pads: PD1666-360
- Rear pads:
*Please note our pads do not have a provision for OE (pin type) wear sensor.
ROTOR WT. COMPARISON (LBS) | FRONT | REAR | TOTAL/SIDE | TOTAL/CAR |
OE Iron 360x32/350x28 | 21 | 16.5 | 37.5 | 75 |
RB CCB 380x34/350x28 | 14 | 10.5 | 24.5 | 49 |
Wt Saving | 26 |
Compared to OE CCB replacement cost:
Brake pads:
Brake rotors:
