- 2 ea Front two piece rotors (360x32 vs. OE 363x30)
- 2 ea Rear two piece rotors (330x12 vs. OE 330x10)
- Brake pads (optional)
RB front rotors are 360mm which fit pad better than OE so no rusty lip is developed like OE would.
RB rotors are made 2mm thicker than OE (front & rear) for extra thermal capacity, but can still fit OE calipers and pads w/o fitment issue.
ROTOR WT. COMPARISON (LBS) | FRONT | REAR | TOTAL |
OE | 25.7 | 11.9 | 37.6/SIDE |
RB (2mm thicker) | 19.1 | 10.7 | 29.8/SIDE |
WT. SAVING | 6.6 | 1.2 | 7.8/SIDE |
WT. SAVING | 15.6/CAR |
Can save 15.6 lbs of upsprung weight per car even with heavier duty discs (2mm thicker on both front and rear than OE)
Replacement rotor ring:
