Quick view sku: POR-IRP-11 380/380mm RB Caliper & Rotor Pkg. for Porsche 991 Turbo S, Turbo & 981 GT4 (P/N 2427 & 2428) $6,474.00 $6,150.30 Compare
Quick view sku: PD1416-391 [PD1416-391] RB XT910 Brake Pad: 991 Porsche C2S, C4S, GTS, Cayenne, Panamera $233.00 $221.99 Add to Cart Compare
Quick view sku: PD1416-3R7 [PD1416-3R7] RB XR70 Brake Pad: 991 Porsche C2S, C4S, GTS, Cayenne, Panamera $315.00 $299.99 Add to Cart Compare
Quick view sku: PD1664A-391 [PD1664A-391] RB XT910 Brake Pad: 991 Porsche C2S, C4S, GTS with RB 380/380 BBK Only $350.00 $332.99 Add to Cart Compare
Quick view sku: PD1664A-3R9 [PD1664A-3R9] RB XR90 Track Pad: 991 Porsche C2S, C4S, GTS with RB 380/380 BBK Only $467.00 $443.99 Add to Cart Compare
Quick view sku: 2501 Porsche 991 Turbo Iron Repl (15mm) pcd=222 $3,421.00 $3,249.95 Add to Cart Compare
Quick view sku: 2181 RB 2pc Rotor (380x34) for Porsche 991 Turbo Front (5-Lug - Not for GT3 w/Center Lock); 997 GT3 pccb to Iron Conversion $1,520.00 $1,444.00 Add to Cart Compare
Quick view sku: POR-IRK-13 RB 2pc Rotor Kit (410/390) Oversize for Porsche 991 Turbo S, Turbo & 981 Cayman GT4 (P/N 2500 & 2501) - 5 Lug Hub (Will not fit GT3 Center Lock) $4,200.00 $3,990.00 Choose Options Compare
Quick view sku: POR-IRP-07 RB Caliper Brake Kit for Porsche 991 Turbo & 981 Cayman GT4 w/5 Lug Hub $10,884.00 $10,339.80 Add to Cart Compare
Quick view sku: POR-IRP-03 RB Caliper Kit for Porsche 991 Turbo & 981 Cayman GT4 w/5 Lug Hub $12,254.00 $11,641.30 Compare
Quick view sku: POR-IRK-09 RB Iron Rotor Repl. Stock Porsche 991 Turbo & 981 Cayman GT4 (P/N 2427 & 2428) $2,737.00 $2,600.15 Add to Cart Compare
Quick view sku: POR-IRK-05 RB Iron Rotor Stock Repl. (380/380) Porsche 991 GT3 (non PCCB) (P/N 2421 & 2422) $2,737.00 $2,600.15 Add to Cart Compare
Quick view 380/380mm RB Caliper & Rotor Pkg. for Porsche 991 Turbo S, Turbo & 981 GT4 (P/N 2427 & 2428) Click here for details on development and comparison of the Ultimate Brake Upgrade for Nissan GT-RThis $6,474.00 $6,150.30 Compare
Quick view [PD1416-391] RB XT910 Brake Pad: 991 Porsche C2S, C4S, GTS, Cayenne, Panamera RB Brake Pad Selection Guide $233.00 $221.99 Add to Cart Compare
Quick view [PD1416-3R7] RB XR70 Brake Pad: 991 Porsche C2S, C4S, GTS, Cayenne, Panamera RB Brake Pad Selection Guide $315.00 $299.99 Add to Cart Compare
Quick view [PD1664A-391] RB XT910 Brake Pad: 991 Porsche C2S, C4S, GTS with RB 380/380 BBK Only RB Brake Pad Selection Guide $350.00 $332.99 Add to Cart Compare
Quick view [PD1664A-3R9] RB XR90 Track Pad: 991 Porsche C2S, C4S, GTS with RB 380/380 BBK Only $467.00 $443.99 Add to Cart Compare
Quick view RB 2pc Rotor (380x34) for Porsche 991 Turbo Front (5-Lug - Not for GT3 w/Center Lock); 997 GT3 pccb to Iron Conversion $1,520.00 $1,444.00 Add to Cart Compare
Quick view RB 2pc Rotor Kit (410/390) Oversize for Porsche 991 Turbo S, Turbo & 981 Cayman GT4 (P/N 2500 & 2501) - 5 Lug Hub (Will not fit GT3 Center Lock) This kit includes: 2 ea. Front RB two-piece rotors 2 ea. Rear RB two-piece rotors 1 set Front RB street pads 1 set Rear RB street pads 1 set Caliper spacers & hardware Replacement disk: Front: D603-01Rear: D601-06 Brake pads included in this kit... $4,200.00 $3,990.00 Choose Options Compare
Quick view RB Caliper Brake Kit for Porsche 991 Turbo & 981 Cayman GT4 w/5 Lug Hub This kit includes: 2 RB 6-Piston front caliper (7075-T6 forged aluminum alloy) 2 RB 4-Piston rear caliper (6061-T6 forged aluminum alloy) 2 Front RB Iron Rotors (410x34mm) 2 Rear Rotors (390x30mm) $10,884.00 $10,339.80 Add to Cart Compare
Quick view RB Caliper Kit for Porsche 991 Turbo & 981 Cayman GT4 w/5 Lug Hub Features and Benefits:Easy, bolt on installation.Stainless steel one piece piston reduces heat transfer to brake fluid.Built-in dust seals, no boots to burn out like OE's external dust boots.Pad sp $12,254.00 $11,641.30 Compare
Quick view RB Iron Rotor Repl. Stock Porsche 991 Turbo & 981 Cayman GT4 (P/N 2427 & 2428) This kit includes: 2 ea. front RB two piece rotors 2 ea. rear RB $2,737.00 $2,600.15 Add to Cart Compare
Quick view RB Iron Rotor Stock Repl. (380/380) Porsche 991 GT3 (non PCCB) (P/N 2421 & 2422) Brake pads included in the kit is for street driving, for off-street applications please use the links below.Front: PD1773Rear: PD1740 Brake pad Selection Guide Replacement rotor ring:Front: D501-04Rear: D501-07 $2,737.00 $2,600.15 Add to Cart Compare
